Deep finned aluminium sump
#21
is this what you mean? standard depth alloy with fins??? http://www.7ca.co.uk/QE27.htm
I have a Speedex sump on my car but i never fill it to the max 6 pints and usually have 4 pints in it. Doesn't leak as much as tin ones which is why I use it. Disadvantage is attaching it to the crankcase after I replace the engine but hopefully not a regular occurence
Phone rubbish so can't correct spelling!
Sumps seem hard to come by just at the moment. On my special, when I get a sump, I will add a windage tray and an extension pipe to move the pick up to be more central. That's meant to help with certain styles of driving as Chris put it!
Simon
(24-10-2018, 07:09 PM)Michael D Wrote: is this what you mean? standard depth alloy with fins??? http://www.7ca.co.uk/QE27.htm
Michael , tried that Avenue , all out of stock. That as you say is standard,I’m looking for semi deep, and there is also a deep
But thanks
But thanks
If you have a friendly TIG welder how about fabricating one? 3mm plate with a flange of say 8 mm.
Sounds like a business opertunity for someone if none currently available
Users browsing this thread: 26 Guest(s)
