Car type: 1933 RP Standard(ish) Saloon
To be fair my crankcase is only "shiny" because of the mechanical action of the wire brushes I used. I didn't polish it on purpose, it was just to give it a good clean. I'm sure it will dull off over time as the aluminium oxidises. The main purpose was to remove the crud from inside it. Flash photography accentuates it.
Car type: Seven Special
I have used aluminium wheel cleaner sprayed on, left for a little while then hot pressure washed off. Works well especially on old baked on oil inside the case. Some additional agitation with stiff brush on stubborn bits. Important to remove all traces though, hence final washing.
A couple of years ago I was given a 1933 crankcase and on getting it home I plonked it in a large tray with some paraffin to clean it after lifting it out the tray looked like a holiday beach there was as much sand as paraffin, some idiot had sandblasted it.
Has anyone used laser ablation to clean water and oil passages? This should leave no residue so would seem an ideal method?
Soda blasting works well washed out with hot water as its only chrystals and water soluble. Terry.
Personally, I do not use anything that has abrasive media attached to it or is used as the method of removing surface dirt or residue. Chemical cleaners work well but you have to ensure they will not attack the base metal. Getting oil ways or internal crevasses are all ways difficult to get clean. For oil ways pipe cleaners etc and high pressure air to blast out the residue works.
Cheers,
Stephen
For oilway cleaning I use some small brushes to clean them followed by installing a oil pump standing the crankcase in a tray of clean paraffin and spinning the pump with an electric drill while removing the oil way plugs starting with the one nearest the pump and working towards the one furthest away. I've resisted that treatment on the sandblasted crankcase as it will wreck the pump.
FWIW I fear an oilway plug coming adrift far more than I fear crud in the passages - that might just be my own personal set of priorities as I run pressure-fed engines with oil filters, and have rarely had to start work with a case which was really crusty. Removal of said plugs - the two grub screws along the rear edge of the sump - can sometimes be very difficult, and the threads are seldom tip-top by the time you've finished (again, possibly because I'm ham-fisted). Consequently I'm nowadays more inclined to leave sound plugs in place and sweep out the oilways with flexible brushes, which are readily acquired from eBay. It's not impossible.
