Crankcase cleaning
Question
I have a very grubby crankcase i would like cleaning but just back to factory issue not sparkling!
Bead blasting Vapour blasting -any recommendations ? Thanks
I have a crankcase at the vapour blasters at the moment. Will probably done over the weekend. Last one they did was perfect. I seal off oil ways with gaffer tape and leave the blanking plugs in place so as not to get blasting medium into the oil ways.
I don't like vapour blasting, as I think it leaves a finish that looks too modern for vintage cars and (perhaps more importantly) could potentially introduce tiny glass beads into the lubrication system.
I have a developed a way of doing this that uses no media and leaves a natural finish to the aluminium.
I don't want to be accused of hawking on here, but, if you would like to know more and the costs involved, feel free to email me on info@albaaustins.co.uk
Some while ago a customer brought me a set of engine parts including a crankcase which he’d had vapour blasted. I wish I’d said no, but I didn’t and spent hours trying to clear the impacted blasting medium in the oil galleries. Eventually I gave up and used a different case. The best way I’ve found to clean engines is with degreaser and a pressure washer, or the dishwasher when the lady is not at home.
I’ll second Alan’s suggestion, the dishwasher is brilliant when used on the intense cleaning mode!
Personally I've never quite grasped the point of polishing something I intend to get very dirty as soon as possible.
From an engineering perspective, a few stiff brushes and a washing up bowl of paraffin will do what you need.
If it's very crusty a wire brush in an electric drill will get most of it off.
I buy flexible test tube brushes from eBay to chimney sweep the oilways.
If I can't be bothered my local engine recon shop offers a crankcase dip - I've never been quite certain what they dip it in tbh.
Results can be mixed - some cases come out gleaming, others somehow don't take to it and are merely mechanically clean (and reek for ever after of the solvent).
I personally shy away from blasting for the same reason others have cited - you don't want even the tiniest bit of blast media left behind.
I've never yet tried it, but I believe that later A7 crankcases were painted silver, that's another option.
I adopt the petrol/white spirit method with rags and nylon scouring pads.   After that I use a bath of hot water with plenty of washing up liquid and nylon scourers.   The crankcases don't come out looking like new but I am satisfied that any unwanted crud has been removed. I clean all the other aluminium castings in the same way.  When the engine is built up with the block and head painted black the overall finish is very satisfactory in my eyes.  I want my engines to look old and cared for rather than polished and for display purposes only!
Over the winter months I got bored and decided to clean up a spare crankcase I had. I did it all with a drill and various wire brushes. The case is from 1933 and there were traces of silver paint on it in a few difficult to get to places. The interior has also has a mechanical clear out and the oil galleries cleaned with bottle brushes and acetone. I'm quite happy with how it is, seeing as I'm not intending to use it at the moment.
I might put it in the dishwasher if I do.
[Image: 20251220-125624.jpg]
[Image: 20251220%20125232.jpg]
Many years ago, a pre‑war Rolls‑Royce Phantom wheezed into the yard of a local restorer of high‑end vintage cars. Once the smokescreen from its arrival had dispersed—several minutes later, and only after the neighbours had lodged complaints—the driver explained that its 7.3‑litre V12 had covered fewer than 3,000 miles since a very expensive rebuild.
Sensing that something was amiss (beyond the obvious fog bank), the proprietor phoned the company responsible for the work and, posing as a potential customer, inquired about their approach to engine rebuilding. The answer, delivered with the confidence of people who really shouldn’t be confident, was that they bead‑blasted virtually everything. Everything. Including the crankcase. And the crankshaft. And presumably anything else that didn’t run away fast enough.
Armed with this revelation, the restorer dismantled the engine. Using a video camera, he filmed probes being pulled from oilways liberally coated with glass beads—an effect rather like watching a magician produce endless scarves from a hat, except a little more expensive and considerably less entertaining for those responsible.
Now, Reckless, tipped on the wider end and fitted on top with a nicely polished piece of wood, that would make a decent coffee table....
Far too shiny for me!
