Axle tubes
The front stubs on my Ulster were, originally, pre-Semi Girling like your rears, Howard, with the 3/16" flange thickness and were cut down to take hydraulic backplates, probably in the early 1960's. However I don't think they were ever used. When I aquired them around 2010 those backplates and some hydraulic bits were still attached and, as I had no intention of going hydraulic, I sold them for exceptional money, via ebay, to a chap in Germany.
I then looked at fitting Semi-Girling backplates and, with minimal modification, they went on and have been there ever since covering many road miles and over 100 speed events. You can see one of the cut down stubs (hydraulics removed) on the left of the photo below taken when I got them.
Hi Steve
Thanks, quick response as always.
Oops. Slight correction. Modified stubs were removed this last Winter when I overhauled the full steering/hubs/front spring assemblies and replaced with Semi Girling stubs. I'd forgotten - I blame it on my age!!
(02-06-2025, 07:02 PM)Steve Jones Wrote: Oops. Slight correction. Modified stubs were removed this last Winter when I overhauled the full steering/hubs/front spring assemblies and replaced with Semi Girling stubs. I'd forgotten - I blame it on my age!!
Hi Steve
I’ve got semi Girling stubs on the front and I guess the rears are probably less stressed than the fronts.
Age…..tell me about it.
