30-05-2025, 01:39 PM
Hi All
I’m putting together a long nose s/w back axle. I’ve recently acquired the banjo and some time ago acquired two axle tubes supposedly from a single vehicle. I’ve spent quite some time getting them clean and I started to mark them out for cutting and shortening.
Notice the problem! Yes two near side tubes!
So does anyone have a spare offside tube? Any A7 tube (apart from the early ones without adjusters) will do, even a D shape axle. I think I can cut off the D shape part and substitute one of the old nearside halves (back to front so to speak). Unless anyone can think of a reason why this won’t work.
I intend to convert to Semi Girling backplates so even a late semi Girling axle is acceptable. On this point, at what angle do you drill the backplate bolt holes to ensure the brake lever orientation is correct?
