Fan pulley
#41
7 County Austins - part number P9 Fan Belt Coil Engine:
http://www.7ca.co.uk/new_parts.htm
A7 Components - part number BD109 Fan Belt Coil Engine
https://www.a7c.co.uk/spares.php#engine
The Seven Workshop - part number R0044 Fan Belt Coil Engine (approx 5/8" wide)
https://www.theaustinsevenworkshop.com/p...oil-engine
Going off on a bit of a tangent, does anyone know how the length of a flat belt is measured? Inside or outside?
We supply a variety of flat belts (https://store.lathes.co.uk/belts) and the inside length is the way to go; we measure them laid flat and recommend the following method:
"On all systems, set the two pulleys nearly as close together as possible and measure the belt length as follows. Use either a non-stretch fabric dressmaker's tape or a long strip of paper that can be wrapped around the pulleys, overlapped and marked. Lay the paper flat and measure the length"
Belt Width:
The flat belt can be the full width of the pulley - with one exception, a pulley with side flanges. If flanges are fitted, leave a couple of mm clearance at each side or the belt will try to climb up one of the faces.
https://store.lathes.co.uk/measuring-drive-belts
(11-02-2022, 09:35 PM)Ruairidh Dunford Wrote: For others, this link illustrates the variety currently available new.  Also helps identify what you have.
https://www.theaustinsevenworkshop.com/s...ery=Pulley
Thanks, Very useful.
As part of my ongoing "clearing out rubbish" project I must go and identify the loose ones scattered around (as long as I can find them!).
On another leg of the same project this morning I sorted through about 7 or 8 old containers of mixed nuts and bolts and now have a sizeably replenished stock of decent BSF fasteners - and a very heavy workshop bin.
c
