Starting handle casting Effective bodges
I am not a bodger by nature, but......My starting handle is a bit loose in the (rather moth eaten) crumbly casting. I have seen fix uppers involving sleeves etc, but really all I want is to stop it rattling and dribbling! the shaft can't be removed without taking the casting off, but can I perhaps push in a sleeve/bung made of a plastic, deformable material that is better than (say) plasticine !!!!! Or something with an O ring??
I made a PVC sleeve to take up the slack on a shortened nose. Make sure its not to tight as its easy to crack the casting, if i made another i would leave a small flange on the outer end.
I have made a 1/4 thick rubber washer that fits over the handle which pushes up to the face of casting after starting. It stops the ingress of water  and dust when trialling.
Andy
Thanks very much, I will have a go!
