DFL Dynamo and the NP1 Regulator
Back in times past I bought a modern type regulator from Mick Kirkland that was designed (I think) by Nick Plevan.
It's been on my shelf for decades and now I get round to using it can I find the instructions, can I hell.
Does anyone have, through a better filing system than I clearly have, the instructions for installing it and importantly adapting a mag engined DFL dynamo to 2 brush operation.
Thanks
Charles
I've got a pdf of the instructions for the NP1 regulator, which is attached.
Good luck!
Thanks Martin, but attached where?
I can't see them.
If you could email them to me at
charles@littlewrongs.org.uk
that would be very useful.
Thanks
Charles
I dunno if the instructions refer particularly to the DFL dynamo but if it chances to retain the internal field resistor it might complicate matters.
(01-06-2020, 10:45 PM)Bob Culver Wrote: I dunno if the instructions refer particularly to the DFL dynamo but if it chances to retain the internal field resistor it might complicate matters.
Bob
There is no internal field resistor in a DFL
C
Sorry, the fact that the E comes after the F routinely trips me.
