Car type: '34 RP ,'30 RF
Thanks again all!
Link to E-bay produced the cap, Repair to rotor by the replacement of broken top spring (by a short section of clock spring).
Use of more clock spring to make new cap clips and then breaking up of a more modern set of points-soldering on the contact tips in place of the originals- Then fitting an unworn gear in place of the stripped original and a new condensor seem to have resulted in a DS4 that works.
Ta muchly!!
Ian C
Since you have the hand control connected, I would fit a DJ4. A very simple period correct Austin fitment distributer. The ever wonderful Tony Leslie usually has a ready-to-fit unit in stock for a very sensible price. Highgly recommended. BTW Nice car, had a good look at that one the other day, and liked it very much. W
That looks like the 'Bosch' converted distributor - available in at least two variants - good and bad copies. Black caps are also available which look much less obvious.
Steven,
I have 4 DS4s on the shelf, all done with new points new caps (can't remember on gears) and ready to fit. I need to go out in the garage later and will take a look at them and let you know.
Normally, caps are about £10 when I buy them, £30-35 for a DS4. Points £4 then £10 for labour I am not much of a business man! I would say about £60. DS4's done like this have been proven up to 7000rpm.
Also I drove through Cranleigh today. I live 15 minutes away.
Thanks
Tom
Car type: 1931 rm saloon
Hello Tom
Do you have any DS4 units for sale ?
I need one for my car as the cheap bosch unit is nothing but a pain.
Please let me know if you have one ready to go and I will be more than happy to pop a cheque in the post.
Thanks agin Paul
Will,
I will check if I have any old points, but the points I fit need a slight modification and a plastic baseplate in the bottom of the distributor body.
Thanks
Tom
