Valve Data
Try Peugeot 205 valves.
Over 4" long, 7mm stem, available from about 29mm to 40mm+
C
Thanks Charles,
hadn't considered going French.
Is a Austin/Morris 1300 longer than a a Mini/Minor?
Hope you don't mind me adding.
If you need longer springs to fit.
I have a large quantity of ULSTER & GRASSHOPPER valve springs.
Tony.
(17-01-2019, 08:41 PM)Robert Foreman Wrote: Thanks Charles,
The Peugeot valve is very handy for many old vehicles because it's long enough to shorten to fit many different cars.
I do remember that A Series valves came in different lengths for different specs, but not massively different.
C
