Bill Sheehan
Unregistered
(04-09-2017, 06:17 PM)Timothy P Wrote: (04-09-2017, 06:06 PM)David.H Wrote: Thanks Timothy for that information.
Owner is a bit hazy, but I am trying to find what I can...I will keep you all posted!
D
Most welcome, I do like tracking down info on cars, always something new to learn.
Hope your search goes well.
David - if, as you say, it's a steel-bodied Chummy, there's every chance that the body was built in Oz - so it may have travelled even more than that suggested! (After 1924 the Chummy was imported in chassis form with floorpan and original aluminium scuttle only (apart of course from wings, lights etc). Being a '32, that of course shouldn't apply, Seven bodies by then were mostly all steel, but worth a thought?. Any chance of photos? - then we may be able to help more. Cheers, Bill
Now there is a thought! I have recently had an AG & this looks VERY similar, but I probably won't know until I get my hands on it & look for the AG on the transmission tunnel. I am pretty sure it has a later engine (small hint: an AC fuel pump - not connected!) & a scuttle tank & possibly a 4 speed box. Probably hasn't run for 25-30 years, but the engine turns over nicely......so ever the optimist, my last 2 cars fired up with a little TLC after a long slumber.
All will be clear in about 6 weeks!
06-09-2017, 06:55 AM
(This post was last modified: 06-09-2017, 06:55 AM by Martin Prior.)
UK, Australia(?), Hong Kong, California and (presumably) back to the UK!
My RP is almost the same age and as far as I am aware has never ventured out of Herefordshire for more than three weeks at a stretch!
I think there is a good chance that the Chassis number is 151214.
