04-02-2024, 12:04 AM
I think we are taking about different fixings, Charles, the Mag Dynamo is clamped with an oiler fixing on top.
04-02-2024, 07:12 PM
Hi All
Not just today but over the last week or so I’ve swapped the magneto engine that came in my van with a coil engine that I built as a spare about two years ago. The van is very late 1928 so would have had a coil engine. The magneto engine was attached to a four speed box and the conversion had not been engineered very well so my spare three speed is now in the car. I had hoped to start her up but a duff condenser put paid to that. Hopefully tomorrow! Cheers Howard IMG_0807.jpeg (Size: 111.42 KB / Downloads: 418) IMG_3952.jpeg (Size: 119.88 KB / Downloads: 418)
Rather pleased. I finished rebuilding my three-bearing engine recently and sent it away to be test-run and put on a dynamometer. I am advised that it ran well and was producing 21bhp. Should be getting it back in the next few days.
I am rebuilding each piece as it comes off from the car. I just need to sort out the brake cross-shaft and handbrake and then I can start on the chassis itself. Jamie.
08-02-2024, 11:12 AM
That’s a great result, I’ve had a couple of really good three bearing motors that have performed well.
08-02-2024, 03:07 PM
Having completely re-made the roof last Autumn, I had nervously avoided the test that had to be done, to push it out in the rain to see if it was water-tight. The rain today gave the ideal opportunity and I finally summoned up the courage. Annoyingly, it failed!! However, I am not down hearted, I can see where and why the leak has occurred and remedial work is already underway. More rain tomorrow will give the chance for a follow up test after the repairs have cured over night...
08-02-2024, 04:43 PM
Hugh
I see your rain and raise it with some proper weather. There are many advantages to an outside forge, just not today... field lr.jpg (Size: 652.7 KB / Downloads: 198)
08-02-2024, 04:54 PM
Aye, well you are Oop North whilst I am darn sarf....
08-02-2024, 05:28 PM
Nay bother, I am now officially a hardened northerner. Well nearly, a couple more generations and I'll be a local.
The snow might have stopped play on the anvil but there are still supports to be made for a new mantle from a plank I picked up at a local estate who were clearing some dead oaks. I may be a little off topic now...
09-02-2024, 09:18 AM
