26-04-2020, 09:45 PM
26-04-2020, 10:34 PM
For an amateur trimmer Steve I think you have made an excellent job of your trim cards for the chummy.
Henry, I can't do quotes but you are a paper fetishist.
26-04-2020, 11:54 PM
Ah, yes Robert, but you are a metal fetishist.
27-04-2020, 07:00 AM
Aye Henry, that be true.
27-04-2020, 09:48 AM
(This post was last modified: 27-04-2020, 10:07 AM by Reckless Rat.)
Pottering in the garage today doing a bit of tidying up I came across a tyre maintenance booklet which is dated 1933 and came with the Austin. When I originally acquired the car it had an age related number which was subsequently voided by the local LVLO due to some irregularity concerning a three vehicle cherished mark change and another age related one was allocated to the car, NFF236. I never had a buff log book other than one for another Austin which didn't have the correct numbers. However, casually browsing through the tyre booklet which bore the stamp of SO Broom, Burgoyne Road ( which I presume is a Sheffield address) I found a comment in pencil regarding the tyre pressures for a car reg WY 7811... could it be the original reg of my RP. The number comes up no trace on DVLA.
Booklet
27-04-2020, 11:57 AM
Curious; WY is a West Riding of Yorkshire sequence, issued between 1921 and 1923 ... I suppose it could have been retained and transferred to a later car, this did happen occasionally, but usually only with a far more distinctive number than 7811!
27-04-2020, 01:48 PM
280 Burgoyne Rd in Sheffield is a terraced house too, so I doubt if the name EO Broom as stamped on the booklet was a dealership, if it is in fact from Sheffield. I wonder...
27-04-2020, 03:56 PM
There are several other Burgoyne Roads:
Camberley London N4 London SE25 London SW9 Sheffield S6 Southampton Southsea Sunbury on Thames
27-04-2020, 05:41 PM
(26-04-2020, 07:44 PM)Steve Clare Wrote: Had a bit of fun the last couple of days fitting new interior trim panels to my chummy Very impressive job Steve
27-04-2020, 08:19 PM
If only that Ratchford bookbindery stuff was in wider circulation as it really looks authentic. I have heard about it being used for exterior use too, with a tougher unseen underlay underneath.
Users browsing this thread: 135 Guest(s)
