27-02-2018, 12:22 AM
(This post was last modified: 27-02-2018, 12:41 AM by Zetomagneto.)
(26-02-2018, 04:36 PM)Dennis Nicholas Wrote:No, Dennis, Stuart is absolutely right in his description of rod ends, that's what they are.Rose joints are a brand name of spherical joints, why ask a question then correct the answer?(25-02-2018, 12:01 PM)Stuart Giles Wrote: ttps://simplybearings.co.uk/shop/images/assets/products/ge17c_skf.jpg
(24-02-2018, 08:16 PM)Dennis Nicholas Wrote:(22-02-2018, 12:53 PM)Stuart Giles Wrote: Presume when you say Rose Joints , you mean Rod Ends -Rose Joints are something slightly different.
Hi Dennis,
An issue of nomenclature as you say. When working on this stuff in the past, these were always referred to as Rose joints
Where as this type of thing would be referred to as a rod end.
Being absolutely correct only joints manufactured by Rose Brothers should be called Rose Joints in the same way as anyone vacuuming the carpet with a device made by Electrolux or some other manufacturer shouldn't say that they're doing the hoovering.
BTW, regarding the use of these on road cars, I converted most of the suspension and steering on my road/competition A7 special in the early '80s. I have only recently changed those joints out due to them having some movement. There is an enormous range of qualities of these joints, the cheaper ones tend to be metal to metal, where road grit will cause a lot of wear. I used joints with an integral Teflon/Kevlar (IIRC) interliner between the ball and joint body. These have stood up well to what must add up to considerable road mileage over the years.
Stuart, re the Rose joints nomenclature, I think, like manufacturers, I would refer to your second photo as Rose Joints with threaded shank. Others with a shank fixed to the inner swivel part instead of the hole for a bolt would be studded rose joint.
It is good to hear that your first lot lasted a long time on a road going car. Do you have a makers name (and sizes) for the ones you used?
I have seen some on a manufacturers website that sound similar with a lining, and with seals either side plus a grease nipple. But no prices mentioned.
GEOFF - Boots for joints......can you point me in direction of firm that does them please.
Dennis
Rgds
![[Image: 1280933782-27562.jpg]](https://www.midwestcontrol.com/images/products/lrg/1280933782-27562.jpg)
So only really need shim washers for ruture wear.
