10-08-2021, 05:44 PM
I am working on the wiper motor and now have it running when 6v is applied to the terminals.
It would seem that it has been "worked on" in the past, mostly using a hammer and chisel!
Am I right in assuming that the curved spring touching the pull/push handle is like an on/off switch?
If so, should it make a connection when the end is resting in the groove on the handle, thereby allowing it to run, and break the connection when the handle is pulled to the off position? If so I will need to do some careful bending.
A pic of a working motor would be really useful. I have read the piece on these motors on the Cornwall club page, but the pictures are not that clear.
Thanks!
David
Thanks!
David
