25-06-2021, 12:32 PM
Has anyone experience of replacing the "valve" on Mosely units or otherwise fixing it? Both sides of this Ruby's rear seat still pump up - but the valve has died.
| The following warnings occurred: | ||||||||||||
Mosely Float on Flatness
25-06-2021, 04:41 PM
I'd be tempted to cut a valve out of an old inner tube or even from a "whoopee cushion" and glue it in with a rubber cement from a cycle repair outfit, or perhaps "Copydex" if it's still available.
You won't make it any worse...
25-06-2021, 07:11 PM
(25-06-2021, 04:41 PM)Duncan Grimmond Wrote: I'd be tempted to cut a valve out of an old inner tube or even from a "whoopee cushion" and glue it in with a rubber cement from a cycle repair outfit, or perhaps "Copydex" if it's still available. I'll give it a go. As you say, it won't make it any worse. And it might make it better.
25-06-2021, 07:48 PM
We need to know, Tony, have you tried to inflate the air cushion by blowing down that perished rubber valve?
I did on my first Austin 7, a Mk 1 Ruby back in 1975, and it wasn't a pleasant experience!
25-06-2021, 08:27 PM
Very old bicylce and car tubes had valves not moulded in but with thr rubber captured between a flange and a washer. If can acquire from someone and still purchase patching in sheets, could make up. I used to recover bike tubes where the bike had been wheeled flat so the valve pulled out.
25-06-2021, 08:35 PM
(This post was last modified: 25-06-2021, 08:40 PM by Tony Griffiths.)
(25-06-2021, 07:48 PM)Malcolm Parker Wrote: We need to know, Tony, have you tried to inflate the air cushion by blowing down that perished rubber valve?Yes, it did blow up - and the air that came back was, indeed, rather unpleasant.... (25-06-2021, 08:27 PM)Bob Culver Wrote: Very old bicylce and car tubes had valves not moulded in but with thr rubber captured between a flange and a washer. If can acquire from someone and still purchase patching in sheets, could make up. I used to recover bike tubes where the bike had been wheeled flat so the valve pulled out. Thanks for that info, Bob. I'll see what I can find.
25-06-2021, 09:26 PM
25-06-2021, 09:44 PM
Tony,
If you're feeling brave you could make your own from inner tubes, there has been some discussion on the forum previously. My front ones were successful but I must admit by the time I got to the back seat I'd had enough and opted for a sheet of foam!
25-06-2021, 11:09 PM
(25-06-2021, 09:26 PM)Mike Costigan Wrote: Maybe you can bond-in something like this: I'll check how much decent rubber surrounds the damaged valve - they might just work.
26-06-2021, 08:00 AM
Cut a small hole in a large repair patch, bond the valve in, and then apply the patch to the remains of the original tubing.
