26-04-2020, 05:27 AM
Hi all
I can’t lift the torque tube out of the diff casing
Any thoughts?
Geoff
Any thoughts?
Geoff
Cant remove torque tube from diff housing
Hi all
I can’t lift the torque tube out of the diff casing Any thoughts? Geoff
26-04-2020, 06:13 AM
(This post was last modified: 26-04-2020, 06:18 AM by Bob Culver.)
The pre Ruby diff has a ball pinion race (fittable to all) whcih may be a neat fit (or Loctited) in the housing, so requires moderate persuasion. (from distant memory the roller bearings had some setscrew arrangemnt to retain the outer ring. I dunno if this can be fitted with a ball race but if so would prevent withdrawal.)
(Just noticed 1938 so unlikely, unless a non standard roller with stepped outer fitted)
26-04-2020, 11:55 AM
It looks as though you would get two levers in on opposite sides; if it was mine I would use two long tyre levers, but you do need to have two long tyre levers. Mine have tapered ends with convenient slight bends in them.
Robert leigh
26-04-2020, 12:28 PM
Sometimes they slip out easily, sometimes the need persuasion. A couple of tyre levers as above normally defeats the latter.
26-04-2020, 01:08 PM
Thanks all. I’ll try that tomorrow. Cheers Geoff
26-04-2020, 03:00 PM
(This post was last modified: 26-04-2020, 03:04 PM by 1938austin7.)
I popped out to the garage before bed and got it this far with levers and then tried two bolts to work as pullers, but got to a stage where it would not move again. Do you think I will be able to get the diff centre out now without going any further?
26-04-2020, 03:33 PM
Erm .... (Asking the rest of the Forum, because I can't remember) Does the bearing housing have to come out, too, with the torque tube?
In which case, you need to be working on that - the middle layer between the bit you have already moved, and the main diff housing. If not, I would put some diesel or other thin lubricant onto the bearing outers, and work the whole thing back and forth for quite a long time to free it off. Then try pulling again.
26-04-2020, 03:35 PM
(This post was last modified: 26-04-2020, 03:36 PM by 1938austin7.)
I have been looking at pictures of dismantled diffs on the internet and I think you are right. I need to separate that joint.
Will try tomorrow Cheers
27-04-2020, 12:54 AM
