17-01-2020, 06:16 PM
Hi Douglas, will not be pumping as the bowl is well below bottom of the bulkhead tank. It was one of the reasons that I chose to modify the manifold and turn it upside down. Trying To keep things simple.
SU Carb on a chummy manifold
24-01-2020, 12:28 PM
Just spoke to Douglas via PMs.
He means this one:
24-01-2020, 01:06 PM
Thats a set up indeed !
Does anyone know where the pipe from half way up the inlet manifold goes / does ? I have a screw in there that just blocks it off.
24-01-2020, 01:19 PM
It's the vacuum take-off for the windscreen wiper.
Robert Leigh
24-01-2020, 01:23 PM
24-01-2020, 09:59 PM
A fascinating thread- the different solutions are great, and really nicely crafted.
I like this last image with a simple addition to the down draft manifold, and would consider using a similar system. One question- Do people think the gas flow would be ok with the extra 90 degree extension?
25-01-2020, 02:28 PM
(24-01-2020, 09:59 PM)Steve Clare Wrote: A fascinating thread- the different solutions are great, and really nicely crafted. Well a standard chummy carb would have a built-in 90° bend anyway, so can't be worse!
06-11-2020, 08:15 AM
(13-01-2020, 11:05 PM)Austin in the Shed Wrote: Sorry after several attempts to post photo I've given in,Can't remember how to reduce size .It is very similar to the one pictured by Bob.I didn't find the need to fit a fuel pump as there is enough drop between tank and carb.Hi Dave, Was the inlet face on the manifold parallel with the ones on the engine side or did you have to angle it a bit so the SU would fit?
Mark
06-11-2020, 08:28 AM
How do the interal ids of the aluminium manifold compare with the Ruby type? Variations of the latter enable an air clener between carb and bomet side.
