Car type: 1927 Austin 7
Dear Friends: I am restoring a 1927 Austin 7 (the one with the gas tank behind the dash). I need the threaded brass circle that fits on the top of the gas tank spout. I did order a new gas cap from David Claiborne but it won't fit on the tank because of distoration and general abuse of the threaded brass ring on the top of the gas tank spout.
Cant this threaded brass ring be purchased somewhere in the United Kingdom? The specialists here are stumped by the thread pattern and think it might be of British pipe origin. Help! Pete Kneedler
09-11-2019, 01:56 AM
(This post was last modified: 09-11-2019, 01:57 AM by Tony Griffiths.)
The simple answer is to make a new neck with the around same diameter but with a suitable American thread, braze it into the tank (usual precautions) - and then machine up a cap to fit.
Why not machine it to the same thread as original Tony? Any good turner can measure the tpi and diameter to achieve that.
09-11-2019, 08:40 AM
(This post was last modified: 09-11-2019, 08:41 AM by Colin Swinbourne.)
If you have the threaded cap, a competent machinist will be able to determine the thread size and machine a new threaded section to fit (whilst taking the obvious precautions!)to the tank.
I’ve just had to do this with my Delage- had the cap, but not the thread to screw it on to so had a new piece turned up...and then had to make the rest of the tank for that to fit to!!
Must be someone here who knows what the original cap thread was surely?
hi
Yes we can supply a threaded ring to fit your cap tel 01202 625242 and we will sort it out Austin reproduction parts
willie
11-11-2019, 03:08 AM
(This post was last modified: 11-11-2019, 03:09 AM by pete kneedler.)
Hi, Willie: How much will a new threaded ring to fit my gas cap cost? Pete
Hi, Willie: How much will a new threaded ring cost (for my new gas cap)?
