21-03-2019, 05:09 AM
Unless it's been done before, then you only need hack the ring off and perhaps double check the diameter.
Rust pitting on flywheel
21-03-2019, 11:53 AM
Given that the flywheel is both cheap and easy to replace with a better one at this stage ( and a total bloody pain to replace if the surface causes issues) I can see no logic for sticking with this pitted one.
Charles
22-03-2019, 12:16 PM
Charles, I can't fault your logic, fortunately I'm in no hurry to resolve the issue of the flywheel as I'm in the early stages of my restoration, it'll be quite a while before engine / clutch go back together so meanwhile I'll keep my eyes open for a suitable replacement.
Many thanks for your input. ..... Phil. |
