07-10-2018, 02:59 AM
I always believed that the Benjamin Horn was attached to the firewall with a z bracket until replaced by the Rist which was then fitted to the strut between the cowl and the firewall on a two bolt bracket alongside the bonnet bracket.
But- strictly for Anoraks- I was told yesterday that the Benjamin and Rist Horns were briefly fixed to the Cylinder Head !
At first I was not sure but I then checked this out- in The Original Austin Seven, page 65, there is a picture of the engine bay of a 1926 R Saloon showing clearly a Benjamin Horn attached to the two offside rear head studs, then Wyatt - illustration 26 1928 Tourer (facing page 65), also shows a Rist Horn fitted to the two offside rear studs.
I am not sure how long this head fitting lasted but the Spare Parts books don't appear to show the Benjamin Horn being supplied with a two bolt bracket.
As an interesting aside my 1929 Australian bodied fabric saloon has an 'old stock' Benjamin horn on the strut between the cowl and the firewall on a two bolt bracket which I assume would match the head stud spacing, instead of a Rist which would be usual.
Cheers, Tony.
Cheers, Tony.
