  • 1 Vote(s) - 2 Average
Positive or negative earth
DThe I am in the process of completely rebuilding my 1934 rp saloon.As the car has to be rewired what are the pros and cons of wiring negative or positive earth.
I'll stick my neck out a bit and say that the difference is largely theoretical, I've used both over the years without issues. Do make sure your dynamo and coil are set up with the corresponding polarity. Ideally run your wiring directly back to the battery rather than earthing through the body, and use the thickest wire you can in order to minimise voltage losses.
Have a read of this and all will be made clear.
http://www.rrec-northeast.co.uk/positive_negative.pdf
(29-05-2018, 11:24 AM)Nick Salmon Wrote: Have a read of this and all will be made clear.
Thank you nick After reading this i’ll Stick to the original positive earth system used on the car.
Good afternoon. were RP's positive earth?
I have always believed that positive earth wasn't introduced until 1936.
Stuart
(29-05-2018, 12:48 PM)IStuart Joseph Wrote: Good afternoon. were RP's positive earth?
Stuart
Hi Stuart Well the car was in pieces when I bought it and there was a short battery lead to the chassis with a positive symbol on the connecter.Of course this doesn’t mean it was original to the car.Someone in the past has fitted a later 3 bearing engine so maybe the car was negative earth originally.
Ken
The List of Production Changes shows: Negative earth up to December 1935. My 1933 RP is negative earth.
David
(30-05-2018, 10:51 AM)David Cochrane Wrote: The List of Production Changes shows: Negative earth up to December 1935. My 1933 RP is negative earth.
David
Hi, my MK1 Ruby was registered on the 10th July 1935 and the numbers correspond to manufacture in April 1935 as she has all her original matching parts and it's wired as positive earth.   Huh
My March 1935 Ruby is negative earth.
John Mason
(30-05-2018, 08:43 PM)John Mason Wrote: My March 1935 Ruby is negative earth.
John Mason
my 33 RP is positive earth
Andy B
