Felt Seals on Ruby Brake Cross Shaft
I believe that there should be felt seals on the brake cross shaft,  but I do not know where they go. There was none on mine when I dismantled it and I cannot find any information on line. Can anyone advise, please? I have non-Girling brakes.
Jamie
Unusually, there have been no responses to my question about felt seals on the Mark 1 Ruby brake cross shaft. Could I reasonably take it from this that no one has experience of fitting them and that they are not actually needed? I confess that I am concluding that they are not, but should appreciate confirmation, if possible.
Jamie.
Had the brake cross shaft off my 1933 Tourer earlier this year and no seals found on the assembly.
I am pretty sure the cross shaft assembly had not been off before (so unmolested) as it had the original
bearings in, all very worn and all three replaced.
Not sure where seals would fit but may have been used on later cars ?.
Martin.
(07-06-2025, 08:59 AM)GM6VXB Wrote: Had the brake cross shaft off my 1933 Tourer earlier this year and no seals found on the assembly.
Martin.
Thank you, Martin.
The state of mine suggested that it, too, was unmolested which leads me to think that there has never been any. It is just that someone made some comments that made me wonder.
Jamie
"felt rings" are listed in the parts list for late Rubies, but not in earlier ones.
Thank you, Simon.
I am concluding that I was misinformed originally. I shall stop trying to work out how to fit seals.
Jamie
