  • 1 Vote(s) - 1 Average
austin 10 carburetter
Hi all, I am after a bit of advice please, I was sorting out a corner of the garage when I come across an Austin10 carb VA26. It is in very good condition and I was wandering can it be used onĀ  A7 Ruby? apart from the jets is there any difference between the actual carb body? can I run it with the A10 jests or re jet it for our Ruby. What do you think?. Thanks. S&P
P..S It is the SWA7 Clubs rally next week held at Bryngarw, near Bridgend.
I suggest you check that the choke tube is the same for both engines. If they are different the jet change for fitting a 10 carb to a 7 will involve some experimentation, and standard 7 jets are unlikely to give good results.
Using an A10 carb on and A7 makes the tick over hunt and gives you a flat spot on pick up.
Hi Robert and Ruairidh .And thanks for all the information. Looks like I will re fit the SU. Anybody wat too buy a Austinn10 carburettor? S&P.
I seem to remember boring out the restriction in the manifold and fitting the A10 Carb was considered a go faster modification.
I think Father did this to the Black Magic Box in the 1970s.
I also have a memory of bits of copper wire being inserted into the jets to alter the size as a quick and dirty experiment.
I have a pair of Riley side draft zeniths to play with as a mad experiment !!!
The spacing is almost spot on and I will put them on the manifold that had twin Amals on it.
