austin 10 carburetter - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: austin 10 carburetter (/showthread.php?tid=10027) |
austin 10 carburetter - phillips - 30-05-2025 Hi all, I am after a bit of advice please, I was sorting out a corner of the garage when I come across an Austin10 carb VA26. It is in very good condition and I was wandering can it be used onĀ A7 Ruby? apart from the jets is there any difference between the actual carb body? can I run it with the A10 jests or re jet it for our Ruby. What do you think?. Thanks. S&P P..S It is the SWA7 Clubs rally next week held at Bryngarw, near Bridgend. RE: austin 10 carburetter - Robert Leigh - 30-05-2025 I suggest you check that the choke tube is the same for both engines. If they are different the jet change for fitting a 10 carb to a 7 will involve some experimentation, and standard 7 jets are unlikely to give good results. RE: austin 10 carburetter - Ruairidh Dunford - 30-05-2025 Using an A10 carb on and A7 makes the tick over hunt and gives you a flat spot on pick up. RE: austin 10 carburetter - phillips - 31-05-2025 Hi Robert and Ruairidh .And thanks for all the information. Looks like I will re fit the SU. Anybody wat too buy a Austinn10 carburettor? S&P. |
