28-05-2025, 03:39 PM
(28-05-2025, 10:36 AM)Reckless Rat Wrote: Personally I'd rather replace the part. It's a critical part of the braking system and if it's going to fail it will be in extremis, when you really need it not to. If this is cast steel then it will need a welding specialist to do a "proper job" on it, using stellite rods and heat sinking.
Agreed Bruce, but it seems Jamie has a welding company on-board. I see now that the welding company are against welding this so let's hope a replacement turns up.
