Headlight Bulb
Good evening Alfie.
I am interested in the type of headlamps fitted to your RN. Currently I am preparing a series of articles on A7 lighting and I have found that the early RN's had Lucas R47's fitted with 'Lucas Graves' double filament dipping headlamp bulbs later being changes to the Lucas type 35/32 still fitted with the 'Lucas-Graves' bulbs and both with 'reeded' glasses.
These bulbs are still available but are more usually known as 'Bosch' bulbs. They have a larger diameter metal body and small and larger rectangular lugs (unlike the round pins normally fitted to bulbs), the purpose of these lugs is to ensure that the bulbs are inserted the correct way up to give the dip/main orientation.
The bulbs that have been identified as available would fit the 'scuttle' lamps (raised in an earlier posting) although there is no facility for focussing them.
Regards from Staffordshire - the creative county.
Stuart
Headlight Bulb - by AlfieM - 05-05-2018, 05:43 PM
RE: Headlight Bulb - by MartinH - 05-05-2018, 05:49 PM
RE: Headlight Bulb - by AlfieM - 06-05-2018, 12:22 PM
RE: Headlight Bulb - by Bill Dixon - 05-05-2018, 06:09 PM
RE: Headlight Bulb - by David Cochrane - 05-05-2018, 07:17 PM
RE: Headlight Bulb - by Chris KC - 06-05-2018, 08:18 AM
RE: Headlight Bulb - by Stuart Joseph - 05-05-2018, 09:59 PM
RE: Headlight Bulb - by Tony Press - 07-05-2018, 02:01 AM
RE: Headlight Bulb - by Timothy P - 05-05-2018, 10:05 PM
RE: Headlight Bulb - by AustinWood - 05-05-2018, 11:25 PM
RE: Headlight Bulb - by Bob Culver - 06-05-2018, 06:54 AM
RE: Headlight Bulb - by JonE - 06-05-2018, 10:00 AM
RE: Headlight Bulb - by Timothy P - 06-05-2018, 04:09 PM
RE: Headlight Bulb - by Dave Wortley - 06-05-2018, 05:07 PM
RE: Headlight Bulb - by Stuart Joseph - 07-05-2018, 09:43 AM
RE: Headlight Bulb - by Timothy P - 07-05-2018, 07:18 PM
RE: Headlight Bulb - by JonE - 07-05-2018, 08:11 PM
RE: Headlight Bulb - by Timothy P - 07-05-2018, 08:27 PM
RE: Headlight Bulb - by Stuart Joseph - 07-05-2018, 09:48 PM
RE: Headlight Bulb - by Timothy P - 07-05-2018, 11:58 PM
RE: Headlight Bulb - by Stuart Joseph - 08-05-2018, 08:40 AM
RE: Headlight Bulb - by David.H - 08-05-2018, 05:27 PM
RE: Headlight Bulb - by Stuart Joseph - 09-05-2018, 09:34 AM
RE: Headlight Bulb - by David.H - 09-05-2018, 09:49 AM
RE: Headlight Bulb - by JonE - 09-05-2018, 09:57 AM
RE: Headlight Bulb - by David.H - 09-05-2018, 12:19 PM
RE: Headlight Bulb - by Stuart Joseph - 08-05-2018, 05:29 PM
RE: Headlight Bulb - by David.H - 08-05-2018, 05:49 PM
RE: Headlight Bulb - by Zetomagneto - 08-05-2018, 05:55 PM
RE: Headlight Bulb - by Dave Wortley - 08-05-2018, 07:40 PM
RE: Headlight Bulb - by JonE - 08-05-2018, 08:07 PM
RE: Headlight Bulb - by Stuart Joseph - 08-05-2018, 09:22 PM
RE: Headlight Bulb - by David.H - 09-05-2018, 02:34 PM
RE: Headlight Bulb - by Stuart Joseph - 09-05-2018, 04:19 PM
RE: Headlight Bulb - by David.H - 09-05-2018, 05:40 PM
