  • 28 Vote(s) - 3.32 Average
(03-05-2021, 09:13 PM)Dave Mann Wrote: The double knurled plunger is the main plunger Tony, my previuos photo may be misleading as the pipe has been through 180 degrees to allow the assembly to be installed 180 degrees from original so I have the reserve in the cab where it can be grabbed if the need arises. Those O rings were advertised in a club magazine and are still on the internet I don't advise their use because by the time you have crushed them up to stop leakage you can't move the taps.
Thanks, Dave. That such a simple thing ..... should prove such a conundrum! I found the same result with the "O" ring seals - though I've not yet tried sanding them down in the lathe; that might work; we'll see.
RE: What have you done today with your Austin Seven - by Tony Griffiths - 04-05-2021, 11:39 AM
Users browsing this thread: Silver Fox, 17 Guest(s)
