Having a few errands to do, and feeling that the loss of flexibility, no bottom end power, I retarded the ignition timing a bit. This was just by guesswork but yes it seems to run better. Another 20 miles or so in the sunshine.
Then the speedo went mad. Sometimes it was ok, then would sweep right around to maximum and back. I'm happy to strip the speedo and fix it, but can it be removed without taking out the instrument panel? I don't really want to undo the choke cable and starter pull wire, and the oils pressure gauge pipe etc etc. Can I get the speedo out on it's own???
RE: What have you done today with your Austin Seven - by andrew34ruby - 07-08-2020, 10:10 PM
Users browsing this thread: 32 Guest(s)
