Steering Box Felt Seal?
Thanks for your thoughts both.
Concerning removal of the gear, I don't possess such a tool Steve; however I found that first warming the gear up a bit, then winding up the puller (3-legged, not 2) as tight as you dare, then giving the head of the puller draw bolt a smart tap with a hammer had the effect of breaking its grip on the shaft. Luckily my puller was the type with "S" shaped legs which can be reversed when you pull the head off one!
A press would be grand, but even so, I couldn't quite work out how to support the assembly in the press if I had one, as you can't readily support behind the gear - not sure I'd want to put that sort of force on the ally cover plate, and certainly not on the seal cap.
Oh yes, one more thing - mark the gear with an indelible pen before removal so you know which keyway it came off!
Noted re the button, thanks for the idea.
Seems we're all agreed! I'm leaving the seal where it is.
I did some crude adjustments this morning so the gears were roughly meshed and then assessed the free play throughout 360 degrees of rotation - I could only find one spot where there was obvious slack, which corresponded to the straight ahead position with the present keyway - which suggests the other two may never have been used - worth a try at least.
Steering Box Felt Seal? - by Chris KC - 05-06-2025, 05:51 PM
RE: Steering Box Felt Seal? - by Howard Wright - 05-06-2025, 06:19 PM
RE: Steering Box Felt Seal? - by Steve Jones - 05-06-2025, 06:54 PM
RE: Steering Box Felt Seal? - by Howard Wright - 05-06-2025, 07:59 PM
RE: Steering Box Felt Seal? - by Chris KC - 05-06-2025, 08:36 PM
