Steering Box Felt Seal? - Printable Version
+--- Thread: Steering Box Felt Seal? (/showthread.php?tid=10053)
Steering Box Felt Seal? - Chris KC - 05-06-2025
I've long known that the steering gear can be rotated 120 degrees either way on its key, but today was the first time I've done it!
Managed to break my 3-legged puller in the process....
Anyway while we're in there, the question arises whether to replace the felt oil/ grease seal on the drop arm (which I have cleverly failed to illustrate here).
The steel housing is in perfect shape and there's not the slightest gap I could winkle a screwdriver tip into to prise it off.
The bushing has no radial play that I can detect so I'm leaving that alone.
And FWIW the key is a tight fit and looks like it will put up a fight if I try to remove it.
My gut feeling is I may well ruin the felt housing getting it off, I may end up with a worse seal than I have now, and it might best be left alone. Or is there a clever way to pop the cap off without damage?
Any thoughts welcomed!
.jpg   20250605_171541s.jpg (Size: 625.92 KB / Downloads: 136)
RE: Steering Box Felt Seal? - Howard Wright - 05-06-2025
Hi Chris
I’ve looked at two boxes but have never been brave enough to take the gearwheel off. I’m told it needs a press! I’ve always left the felt seal on the arm.
One modification that is very worthwhile is to remove the steel button on the main body, drill and tap for a 5/16” stud. This stud can then be tightened rather than using shims behind the button. It can be locked with a half nut on the outside face.
RE: Steering Box Felt Seal? - Steve Jones - 05-06-2025
I've never found it necessary to remove the felt seal although I did, once, a long time ago as a consequence of replacing the drop arm bush. However, you first need to remove the gear and that can be a problem to say the least as already discussed. If you have access to a press, all well and good. However, an alternative that often works (removed one last week) is to set the sturdiest three leg puller you have that will fit and tighten it's draw bolt with a socket and rattle gun. The 'shock' given by the gun is much more effective than simply tightening the draw bolt although when the gear releases from the taper be warned that the three legs of the puller will fly out and spin round - keep your fingers well away. Also, loosen the drop arm nut but leave it in place on the drop arm thread. It helps to locate the tip of the draw bolt and also stops the gear, puller, socket and rattle gun flying off in all directions. Agree that replacing the button and shims with a set screw and lock nut is a worthwhile mod although I use a 3/8” BSF set screw with the end hardened before fitting.
Hi Steve /Chris
Actually I think it needs to be 3/8” to clear the diameter of the button. My mistake
RE: Steering Box Felt Seal? - Chris KC - 05-06-2025
Thanks for your thoughts both.
Concerning removal of the gear, I don't possess such a tool Steve; however I found that first warming the gear up a bit, then winding up the puller (3-legged, not 2) as tight as you dare, then giving the head of the puller draw bolt a smart tap with a hammer had the effect of breaking its grip on the shaft. Luckily my puller was the type with "S" shaped legs which can be reversed when you pull the head off one!
A press would be grand, but even so, I couldn't quite work out how to support the assembly in the press if I had one, as you can't readily support behind the gear - not sure I'd want to put that sort of force on the ally cover plate, and certainly not on the seal cap.
Oh yes, one more thing - mark the gear with an indelible pen before removal so you know which keyway it came off!
Noted re the button, thanks for the idea.
Seems we're all agreed! I'm leaving the seal where it is.
I did some crude adjustments this morning so the gears were roughly meshed and then assessed the free play throughout 360 degrees of rotation - I could only find one spot where there was obvious slack, which corresponded to the straight ahead position with the present keyway - which suggests the other two may never have been used - worth a try at least.
