06-04-2025, 05:53 PM
(This post was last modified: 06-04-2025, 08:47 PM by andrew34ruby.)
On my December 1934 ARQ mk 1 Ruby the only obstruction is the end of the 'glovebox'. Put your hand in the cubby-hole opening at the passenger side of the car and this space extends to about the vertical centreline of the patent plate. You could put a couple of 2" instruments side by side, one would protrude into the glove box, the other would simply protrude behind the dash.
If you wanted a central instrument you would need to cut out the end of the glove box.
It could all be done, I don't see a problem.
