Ruby Dashboard - Printable Version
+--- Thread: Ruby Dashboard (/showthread.php?tid=9935)
Ruby Dashboard - Jamie - 05-04-2025
I cannot get to my Ruby shell to check at the moment, but does anyone know whether there is anything structural behind the middle section where the patent plate fits? I am considering fitting a different instrument panel in the centre and would need to drill there for the instruments to fit.
Thank you.
Jamie
RE: Ruby Dashboard - Hugh Barnes - 05-04-2025
Also, be aware that on some Rubies, the dashboard is constructed in a structural assembly and then an overlay. Sadly, I cannot tell you on which versions you might find this. But I'm sure someone with better knowledge than I will be along in a minute...
RE: Ruby Dashboard - Stuart Joseph - 05-04-2025
My ARQ Ruby and Mk 1 Pearl both dating from August/September 1934 have ‘fixed’ dashboards that are overlaid by a separate dashboard. An odd over-engineered arrangement that seems to have lasted for about 12 months.
RE: Ruby Dashboard - John Cornforth - 05-04-2025
Hi
An alternative is a passenger side half dashboard, needing no surgery. It still leaves room for gloves/map/Yorkie bar.  Ignore the Air/Fuel meter, that's only temporary:
RE: Ruby Dashboard - David Cochrane - 05-04-2025
I don't have a Ruby to check this, but I was hoping to fit a clock instead of the patent plate on my RP. Unfortunately the RH side of the glovebox is behind where I want it to go. I suspect that the Ruby might be the same.
RE: Ruby Dashboard - Ruairidh Dunford - 06-04-2025
What type of Ruby do you have?
RE: Ruby Dashboard - Jamie - 06-04-2025
Thank you for the replies. It is a mark 1 ARQ.
Jamie
From memory, there is some structure from the glove compartment and also the windscreen opener fixing.
RE: Ruby Dashboard - andrew34ruby - 06-04-2025
On my December 1934 ARQ mk 1 Ruby the only obstruction is the end of the 'glovebox'. Put your hand in the cubby-hole opening at the passenger side of the car and this space extends to about the vertical centreline of the patent plate. You could put a couple of 2" instruments side by side, one would protrude into the glove box, the other would simply protrude behind the dash.
If you wanted a central instrument you would need to cut out the end of the glove box.
It could all be done, I don't see a problem.
Thank you. That is really helpful. I should be able to get at the shell next weekend to see how well the panel that I have will fit.
Jamie
