In comparison to a modern car 18g is thick, but as I said in this case its in comparison to a factory floor pan.
06-06-2019, 11:58 PM
(This post was last modified: 07-06-2019, 12:00 AM by Dennis Nicholas.)
Notice no stiffening shallow channels in floor. My Nippy new floors had them put in by using a couple of very large angle irons (3 X 3) put in the vice held about half inch apart with spacer and a half inch round bar, bent to shape and with each end rounded off, was placed over the gap and a heavyish hammer used to hammer the floor into the gap........mind the man doing it for me is rather good at panel beating......perfik.
Air-riveter and no ear-defenders? Well really! That aside, looks like a grand job.
Rack o't' eye and skew o't' gob are critical to a well set rivet!
I love the teasing trigger on the aircraft tools but I've never used one for hot rivets.
My lack of care of my own hearing in the past has given me permanent tinitus which is often exacerbated if I forget the earplugs. Anyone who comes into my workshop is offered ear defenders. I used to insist that they were worn but gave up in the face of stupidity...
22-06-2019, 10:28 AM
(This post was last modified: 22-06-2019, 10:31 AM by Ian Williams.)
Well not to belittle the serious point, quite obviously stupidity reigns supreme with me Duncan, I have spent my entire working life in noisy surroundings, ignorance was bliss when I was younger and I too have hearing loss as a result. I strongly recommend and use hearing protection with excessively noisy or prolonged operations, don't do as I do children do as I say, but I also accept it is the individuals responsibility to asses the risk posed so try not to preach. I probably have as much hearing loss from being a concert goer and guitarist in a rock band as I do from work or other hobbies, as well as liver damage from drinking too much, and artery damage from to many bacon butties. So if all that and the brain damage doesn't get me I will probably die from radiation poisoning due to the depleted southern hemisphere ozone, that is if rising sea levels don't drown me first.
The way I look at it is if I’d been told 40 years ago that standing next to loud race engines might make me hard of hearing as I got older, would I have changed what I did?
