Here's a question...about steering play as opposed to tightness.
From years gone by I have a vague memory of the MOT allowing as much as 1.5 inches play at the steering wheel, mostly confined to the box. Seemed a bit arbitrary at the time and enforcement was dependant on the tester.
Does this tie in with current thinking? It seems quite a lot but I suppose we have got used to the zero play found in modern cars.
Getting the wheel off the drop arm is one of the notoriously difficult jobs on the Seven.
DO NOT HIT THE END OF THE SPINDLE
It is soft and the gear is very tight.
I eventually had to make a puller out of 5mm plate, put the assembly in the freezer overnight, heat the gear (but it blues easily) and hit the puller bolt with a large hammer - and then it came off.
Then I had to make good the damage I had done to the spindle by hitting it.
It is the obvious thing to do - but don't do it.
Having done that, you then have to lap the gears together with grinding paste.
I have just done that with a box with the gear worn in all three positions. After about 4 hours or so I am about 85% there and will try it to see if I can get away with it.
"Find another box" - this is my other box!
Simon
"Getting the wheel off the drop arm is one of the notoriously difficult jobs on the Seven.
It is soft and the gear is very tight."
My solution was to turn a protective cap for the end of the spindle, you can then use a three legged puller, the gear is still bloody tight on the shaft but a sharp blow to the end of the puller usually frees it, and with the protective cap no damage done.
Mine sounds similar to yours, as you say, a little play helps iron out the bumps. 3" sounds like a recipe for a bit of wandering...
