I had a matched pair of hardened distributor gears arrive today, should I have both fitted or just the one on the Dymomator ?
Car type: 1931 RN, 1933 RP
If you have both, you may as well fit both. I would.
Roly
1931 RN, 1933 APD
Plenty of timing gears being sold as sets at Beaulieu yesterday, says something doesn't it.
What was the problem with Vince’s car in the end Nigel?
02-07-2018, 08:41 AM
(This post was last modified: 02-07-2018, 08:42 AM by Nigel was in Brittany.
Edit Reason: Spelling mistake
He wasn't sure, its a noise he has never heard before, he said it definitely wasn't crank or flywheel lose, it was just a very loud noise. the engine still ran,Derek Shelldon might know more as he went to tow Vince in and RH took him home after lunch. Of course, if he had a dynomator fitted I could understand the noise.
I hope he got it sorted, we drove right past his home on Saturday, en-route to my brother in-law’s house.
Sounds like a sensible decision - the two I have are working as they should since I replaced the new gears with originals. Roly, I think, has a similarly positive experience after doing the same.
