Zenith 26 VA jet seat
Thanks John
I've found that and it does look like both my carbs have that jet under the brass screw plug.
I'm still confused about the jet next to the slow running jet on the top face of the bowl. My old flat bottom float bowl has a jet and under it a tube of some type. My carb with the bowl with the two external tubes has the hole for this same jet but without a thread to fit anything.
I can't see it on the drawing and Im wondering if it was not used on this carb?.
Hopefully I've attached a photo of my 2 carbs . The one on the right being the one I intend to use as the spindle fits nicely. The one on the left is the flat bottom bowl type showing the extra jet
I believe John is correct in saying that the removable jet in the top of the float bowl is an earlier arrangement and the later carbs just have a casting where the “hole” is theoretically the right size so no need for the long jet.
I have noticed this on other Zeniths of the period.
Regards,
Stuart
Thanks, I suspected that.
Thanks for advice.
I have obtained a new throttle plate and spindle
Also found some small fibre washers
Now to assemble and  try out
Also just to note the importance of not mixing up bowls and tops from different 26VA variants. I ran the wrong combination for years and the difference in smooth running from correcting this is significant.
R did a perfect summary of this with pictures some time ago showing matching up numbers of lugs on the top to the number of channels on the bottom of the bowl.
Andy
https://www.austinsevenfriends.co.uk/for...p?tid=2640
Hope I've got this link right.
Thanks
I saw the well described article on the differences in the bowls and their compatable bodies.   I do have one of the other type (with the twin castings on the outer bottom  of the bowl)  but ive been carefull not to mix them up.That carb has worn its throttle spindle bearing holes to a degree i am not happy with although the throttle plate is good it is also different as it has two semi circle cut outs at the spindle position .     As i now have a spare brand new spindle i may try reassembling that carb as well ..
