Austins gathered to start a run organised by the Auckland branch of the Vintage Austin Register. The run, led by the Austin 16/6, went through hilly country in the Hunua area. On a particularly steep hill climb, the 16/6 missed a gear change and came to a standstill. This didn't amuse the following Austin 7's who also had to stop and do a hill start.
This evening sees one of the most fiercely contested Austin 7 events of the year, Round 1 of the Pre-War Austin 7 Club Shoebox Races, to be organised by the West Yorkshire Branch of the PWA7C.
The race will be held in Rawdon on the north side of Leeds.    There will be intense rivalry from the Lincolnshire Branch of the Club some of  whom will be heading North as I write this.
Run under strict rules and regulations, the cars will undergo scrutineering prior to the practice session.  The all up weight must not exceed 12 ounces and the body, made out of a shoebox, has to have maximum and minimum dimensions  and a minimum cubic capacity of 144 cu. inches.
The Boltby entry is pictured, made out of the usable parts of last years spectacularly unsuccessful car.   The driver, Bert Hardon, has also been retained.
Posted prior to the event in case it gets written off in the heat of the action!
Do the CDs produce music as they rotate? The members of a barbers shop quartet, or four string players of a Schubert Quartet? Or does each corner give the vrooom vroom sound of a highly tuned Seven engine, or maybe a Seven Special with a Cirrus engine?
I couldn't detect any music from the CD wheels over the noise of the excited crowd of spectators.   Some of the shoebox cars are now favouring 7" diameter vinyl records for the rear wheels.
A field of 13 cars took part in a series of elimination races and the Boltby car got through all five of these.  Things were desperately close and the Clerk of the Course decided to bring things to a result by having a final run-off of the three fastest cars.
I narrowly missed out on a podium but the Yorkshire/Lincolnshire rivalry was settled satisfactorily by Yorkshire cars being in first and third positions.   A good nights entertainment that also raised money for a local hospice.
Sheffield Group of the PWA7C mid-week run around the Peak District. Mid-week? For those retired or skipping a day's business... The black RN has been in the same family since 1936, and the owner celebrates this by always including, as his mother did before him, a bunch of fresh flowers in a holder on the dash.
Completed repair of one Rist horn where the coil was open circuit, which meant a total strip down to unrivet the coil bobin, make a new bobin and wind the coil
is the Benylin a lubricant for the diaphragm to make the horn sound less like a duck with a sore throat?
"Duck with a sore throat" - I like it, and that's the charm of the Rist. When people spot a Seven, they smile and often wave. If one taps the horn button, the smiles grow wider and the waves more animated.
(Yesterday, 08:41 PM)David Stepney Wrote: is the Benylin a lubricant for the diaphragm to make the horn sound less like a duck with a sore throat?
