Ruby Dashboard
I cannot get to my Ruby shell to check at the moment, but does anyone know whether there is anything structural behind the middle section where the patent plate fits? I am considering fitting a different instrument panel in the centre and would need to drill there for the instruments to fit.
Thank you.
Jamie
Also, be aware that on some Rubies, the dashboard is constructed in a structural assembly and then an overlay. Sadly, I cannot tell you on which versions you might find this. But I'm sure someone with better knowledge than I will be along in a minute...
My ARQ Ruby and Mk 1 Pearl both dating from August/September 1934 have ‘fixed’ dashboards that are overlaid by a separate dashboard. An odd over-engineered arrangement that seems to have lasted for about 12 months.
Hi
An alternative is a passenger side half dashboard, needing no surgery. It still leaves room for gloves/map/Yorkie bar.  Ignore the Air/Fuel meter, that's only temporary:
I don't have a Ruby to check this, but I was hoping to fit a clock instead of the patent plate on my RP. Unfortunately the RH side of the glovebox is behind where I want it to go. I suspect that the Ruby might be the same.
What type of Ruby do you have?
Thank you for the replies. It is a mark 1 ARQ.
Jamie
From memory, there is some structure from the glove compartment and also the windscreen opener fixing.
On my December 1934 ARQ mk 1 Ruby the only obstruction is the end of the 'glovebox'. Put your hand in the cubby-hole opening at the passenger side of the car and this space extends to about the vertical centreline of the patent plate. You could put a couple of 2" instruments side by side, one would protrude into the glove box, the other would simply protrude behind the dash.
If you wanted a central instrument you would need to cut out the end of the glove box.
It could all be done, I don't see a problem.
Thank you. That is really helpful. I should be able to get at the shell next weekend to see how well the panel that I have will fit.
Jamie
