05-06-2025, 05:51 PM
I've long known that the steering gear can be rotated 120 degrees either way on its key, but today was the first time I've done it!
Managed to break my 3-legged puller in the process....
Anyway while we're in there, the question arises whether to replace the felt oil/ grease seal on the drop arm (which I have cleverly failed to illustrate here).
The steel housing is in perfect shape and there's not the slightest gap I could winkle a screwdriver tip into to prise it off.
The bushing has no radial play that I can detect so I'm leaving that alone.
And FWIW the key is a tight fit and looks like it will put up a fight if I try to remove it.
My gut feeling is I may well ruin the felt housing getting it off, I may end up with a worse seal than I have now, and it might best be left alone. Or is there a clever way to pop the cap off without damage?
Any thoughts welcomed!
