Unusual block
Yes the valve holes look similar to that.
They are for stepped valve guides, blocks originally fitted with straight ones do not have the countersink.
Thank you again Ruairidh.
My other blocks, with stepped guides installed, have deep recesses so being different I had assumed this one would take straight guides.
All of this is good news as it seems I to have a perfect block of the correct age for my build.  Smile
It all sounds very good.
You will need the earlier-style valve chest cover which uses a solid cork gasket.
If the standard bores are unsleeved that's a very good block. For the record I've used parallel guides in early blocks without issue.
By reputation "screw in core plug" blocks are made of better material than later ones.
Slightly earlier than mine, which is block number 113124, which has a proper land for the upper edge of the valve chest cover, which suits the later gasket. Screw on core plugs too.
