Unusual block
Hi All,
I'm just gathering together all the components for an engine build. I have several blocks, all with their own problems. I do have one block with standard bores, no broken off studs, and good threads for the water manifold which I was going to use. However, I noticed some quirks compared to my other blocks. First, it has screw in core plugs but not to the usual slotted design which I can imagine are an earlier modification, especially as it has non stepped valve guides. Second, the casting for the valve chest cover studs is different from all the others. Third, the top sealing surface for the valve chest cover is very narrow, and may not be wide enough for the seal. Finally, the top of the bores are "countersunk", much like the bottoms.
The block has no casting numbers on it. I believe the chamfer is not an issue, but will check the distance to the upper ring, and am contemplating machining a wider land on the top edge of the valve chest.
Can anyone give me any indications of where such a block may be from, and any comments about using it.
Thanks
Chris
Engine number 108440 puts it around 1930.
Ruairidh,
Where did you get that engine number from?
Chris
If you zoom into the second photo you can see it stamped onto the gasket face, albeit faintly.
Yes, as Bruce says, they are stamped along the bottom edge of the tappet cover face.
Thank you both.
How could I have missed that ? Very embarrassed.
Should I be concerned about the differences I mentioned compared to my other blocks?
What kind of exhaust manifold do you intend fitting?
Were the valve guides not stepped until 1932?
I have a custom built Ulster pattern exhaust manifold I intend to use.
The manifold will not cause any issues.
Does the underside of the valve guide hole look like this?
