Hand throttle sensitivity
Hi James
The throttle linkage does look standard although the lever at the end of the column looks a bit long (could just be the photo). The lever on mine is about 1 3/4”.
The coat hanger choke control is, I think, also standard.
I’m not sure what the other lever to the right of the hand throttle lever does?
