05-01-2019, 09:46 AM
(This post was last modified: 05-01-2019, 09:51 AM by Mike Costigan.)
That looks like a 1932-34 high-frame long chassis, 4-speed gearbox, Girling front brakes with Bowndenex conversion and an interesting semi-rod conversion to the rear brakes; looks like an ideal candidate for a special!
Edit: it has the early-type banjo rear axle, so almost certainly a 1932 chassis.
That's a pre-1930 axle surely? Though I'm not sure what those extra brackets are.
Definitely merits further enquiries in my estimation. Depends what the owner wants for it I guess...
If the red brake drums are anything to go by it may have been a special at some time, or intended to be.
Car type: 1927 Chummy, 1926 Top Hat 1938 Big Seven 1/2 a Trials Chummy
It's an early type back axle, pre late 1929, no side adjusters and short nosepiece. The chassis would therefore suggest itself as late SWB with coupled brakes, 1930 - 32. The last SWB cars were produced in very late '31 into early '32, alongside LWB cars and sold as a "Standard" model.
05-01-2019, 12:42 PM
(This post was last modified: 05-01-2019, 12:48 PM by Ian Dunford.)
It looks to me as though at least the torque tube and banjo and side tubes are earlier than 1929.
Could be; they are brazed construction rather than welded. Don't know when that process changed......
The aluminium bump to the right of the gearbox (looking from the rear) suggests the starter motor is fixed direct to the crank case... So the engine is late '31 on...
It's a good game this... Better than spot the difference!
No, Nick. September '32 onwards.
