12-04-2019, 08:14 PM
Might have to wait a while.
All Alloy Cup progress
12-04-2019, 08:38 PM
Perfect age Alan.
Bill - my father in law worked at Barr and Stroud in thermal optics/imaging - Ken Fraser, he knew Tom’s father who also worked there...
12-04-2019, 08:47 PM
(This post was last modified: 12-04-2019, 08:51 PM by AllAlloyCup.)
Hi Ruairidh
I worked in the Physics Lab along the corridor from Thermal imaging. I was there on one of the first days they got An IR imager working. They set it up in another corridor that the office girls used and it gave some interesting results. As I had a bod toothache that day I became a guinea pig and you could see clearly where the bad tooth was ! When these guys had some spare time they would build themselves an electron microscope!! I worked on EMI 2001 colour cameras and later when I was at BBC at TVC , White City, my manager had one of the colour splitter blocks I used to test!!!! On his desk as a paperweight! Bill G 55280573-25CF-4EC2-86BA-60A49E9B2C7E.jpeg (Size: 65.73 KB / Downloads: 548) F9407870-9B37-421E-B76C-495A73E4FB31.jpeg (Size: 101.47 KB / Downloads: 548) Took some photos of the non standard Hardy Spicer Propshaft and gearbox, both now installed! Bill G Aka AllAllloyCup
14-04-2019, 02:04 PM
Perhaps halfway through this list I might get to start car!
Subject: Jobs Car to do list Fix petrol tap, and fuel filter Grind and paint exhaust manifold, fit Fix valve chest cover with O-ring cord Fix brake light switch and wiring Wire umbilical to control panel Attach steering drag link Install windscreen glass(wiper motor holes?) Paint: throttle shaft, toe board etc refit Sort out pedals and gearbox top Test petrol tank and refit ( slosh if need be?) Make and fit oil pipe Make and fit handbrake gaiter Adjust brakes refit undersills Fit engine in chassis Fit carburettor and linkages Make and fit exhaust down pipe Refit flitches, cow horns and wing supports Rewire remaining cabling Fit new battery cable and battery Finalise floorboards,TransTunnel and seating Check starter and dynamo and fit Time engine with old distributor Refit radiator etc and bonnet Nickel plate door catches etc, Refit doors Fix headlamps Attach all wings, side lamps and flasher Fill all fluids and attend to all greasing points Finish instruments Make carpets Order hood material Make tonneau Commission hood and sidescreens Regards Bill G
14-04-2019, 02:12 PM
Hmm! Running by tea-time then?
14-04-2019, 02:28 PM
Hope to get most of the assembly jobs done by
early June, motoring in earnest in July? Hood may need to wait a bit though. Other things may intrude though as I have DIY list as well!!! DIY list Fix Beach Hut roof New steps and wall to lower garden Finish rear patio stone laying.... etc, etc Otherwise I’ve lots of time on my hands! Regards Bill G
14-04-2019, 06:58 PM
75% finished with another 80% to go then...
14-04-2019, 07:13 PM
Hi Duncan
So speaks the expert .... :-) Bill G
19-04-2019, 02:27 PM
B8F34E2D-D58C-4961-81F3-9B30154B4179.jpeg (Size: 86.56 KB / Downloads: 230) 634E872D-C7D3-49ED-A2DC-DE5FAB4C9587.jpeg (Size: 97.47 KB / Downloads: 230) 04F078AD-72FF-49B0-9F73-0DAB37B50E86.jpeg (Size: 75.89 KB / Downloads: 230) Engine now installed without too much trouble. Plus new battery has found a home under the seat. Ruairidh dropped by to see how I was getting on. Sun out so car work suspended and off to the Beach Hut to do some Spring cleaning! ABF72D89-5C29-4EAE-887B-19F9B2C8792C.jpeg (Size: 140.45 KB / Downloads: 231) Regards Bill G
