29-04-2018, 12:14 PM
The article mentioned by Terry can be found here:
http://www.ba7c.org/technicalArticles/dy...Cover.html
Timing gears
29-04-2018, 01:29 PM
ok, I've read that - but is it something people check for regularly when adding this new part? Should one use a thicker gasket just in case if not confident in assessing such matters?
29-04-2018, 08:19 PM
It is something that should be checked every time a dynamo is replaced, excess clearance through use of an overly thick gasket will cause timing scatter.
29-04-2018, 08:26 PM
Spot-on Ian.
29-04-2018, 09:04 PM
So, what's too much and what's too little when it comes to backlash on the dynamo gear?
I spoke to Vince Leek this week in my search for new timing gears and he recommended .004"
29-04-2018, 09:36 PM
Vince is a man with a lot of experience Colin, certainly someone who's opinion I respect.
29-04-2018, 10:01 PM
Vince speaks - I listen.
