I once aborted an intended overseas jaunt at Southampton when the oil pressure dropped to zero (normally a healthy 35 - 40 psi at least). When stripped down I found a flake of old red hermetite in the oilway completely blocking the entrance to the oil pressure gauge pipe.
It’s not a trade secret.
1. It will take me ages to write it down.
2. I cannot be bothered with the potential teeth sucking that will ensue, if you are a reasonable person I am sure you will relate..
If you want to know, phone me and I will happily describe how I have done it previously.
Don't worry about it Ruairidh. Just idle curiosity on my part. Thanks for the excellent job you did on my sports crankcase.
08-09-2019, 12:53 PM
(This post was last modified: 08-09-2019, 12:53 PM by Charles P.)
Well my diagnosis was correct so I have a complete strip down to solve the problem. I'm going to lap the gear onto the taper and fit the key with the same love and attention that I apply to half shafts. It really is a bloody awkward place for a tuppenny component to fail.
Oddly I'd never heard of this problem until it occurred to me!
Charles
I have recently driven a car with the gauge on zero when running between 30 and 40 mph.
Revving produced a flicker off the stop, from cold it was up to (say - I can't really remember) 10, falling to zero after warming up.
I advised the owner to try swapping gauges, but could it possibly be a sheared key and slipping gear?
I think I would expect more inconsistency if that was the case, but I don't like driving with zero or near zero showing.
Your experiences, please.....
It depends. I imagine Charles’s is a pressure fed engine. In which case zero is definitely wrong. A splash fed engine might well show zero on the gauge when fully warmed. Depends on the gauge.
I agree - our RK sits on zero at 45mph when fully warmed up, always has.
My RP runs between 2 and 4 lbs/sq. in at 30 mph hot, but sinks to zero at tickover. I have to tap the gauge to get it to register again! When cold, the needle leaps to the top of the gauge.
