Hi the fuel tap on my chummy got very tight so I had it off and lapped it together with some tcut now its alot easier to turn but does not fully turn off I see new ones are availably and expensive any one got any tips to whats Happening?Thanks Jeff Blight
I changed to a modern tap which seals properly and is easy to operate. It is basically a lever operated ball type valve. I think it was on Ebay as a motorcycle tap.
+1 for the motorcycle tap. Can’t remember the supplier sorry
Thanks for the help will try one of the Villiersservices ones
Jeff
