Car type: Special 1930 chassis
Good morning chaps,
Need a little help, does anyone have a pattern of a swb radiator support ? I dont believe its complicated but as I'm about to start building up the front end of my car it would be a great help...
Pictures would also be a big help :-)
Many thanks Matt
What type of rad shell do you have?
Many thanks for all the replies, I have a Ulster repo cowl and the short rad brackets will be, now on my wish list...
Just a case of finding them :-) I'll certainly try A7C any other ideas ??
Stuart I'm impressed with your research to find the differences, Dare I ask why :-)
Many thanks Matt
You can ask, Matt, but the answer isn't very exciting!
Some years ago I was having a transoceanic correspondence with a friend who had much the same query as yours. The pictures saved a lot of typing.
They were still lurking in the computer so I thought you might as well see them.
Regards,
Stuart
15-05-2023, 04:29 PM
Thanks Stuart & Ruairidh
now there is a comprehensive list for future special builders :-)
Many thanks for the help
I have a pair of the 'short and Ulster' type brackets but lacking the square radiator support which holds the felt. I feel sure that these bits could easily be made from sheet (I would use galvanised because I have it). If you are interested in my brackets send me a private message and we can talk.
Robert
