Car type: Austin 7 RN 1931
Has anyone transferred the petrol tank on an RN to the rear of the car as per the later models.
I'm getting increasingly concerned about the safety of the scuttle mounted tank directly above the hot engine.
Some will argue that it's lasted, trouble free, for over ninety years and if it ain't broke don't fix it.
Several times I've had a minor spillage despite being careful and it's made me sit up!
Perhaps I'm worrying needlessly but I am getting old!
Barry, you are worrying needlessly...
Petrol auto-ignites at around 280 degrees centigrade, the only thing in the engine bay with a chance of (auto-)igniting it is the exhaust manifold. That said, I've spilled petrol on the exhaust countless times and it just sizzled. Sparks of course are another matter and there are a number of places they might occur - and yes perhaps more under the bonnet than at the back end.
If you are deeply concerned, it shouldn't be a major problem to fit an RP tank (one or two cars have used both to extend range). I would heartily recommend SU 6V electric fuel pumps, available new from Burlen.
Contrary to popular belief it's actually quite hard to ignite petrol except with a spark. Even then it only really fires with vapour close to the air to fuel ratio of 11:1 by weight (that's an awful lot of air).
Petrol landing on a hot surface evaporates almost instantly, it doesn't ignite. The vapour will ignite if there's a spark.
Much more likely to ignite on a hot surface is oil and especially brake fluid. They ignite from the heat before they are fully evaporated.
A lot of car fires were caused by brake fluid being spilled onto a hot surface after an accident. For a long time brake fluid resevoirs were often not mounted securely, that's since been rectified.
Yes I’ve got that on my RP Bruce but the petrol drips from the Zenith too the paint off on about three months!
I think the OP answered his own question, in years of driving a scuttle tank car I never had a problem, even when being a bit careless on fill ups and sploshing petrol about.
That plate of mine has been done in POR15 and no probs since. Mind you the Zenith has been swapped for an SU. No more drips.
I avoid acryilic paint because it's soluble in petrol. At the very least it needs a good coating of petrol resistanr lacquer.
